B
bthielen
Guest
I am a little confused. Art. 547-1(b) This article applies to agricultural buildings where animal excrement may cause corrosive vapors. The scope of this article says it applies to agricultural buildings or "that part" or adjacent area. I will be wiring a 52' x 75' x 12' pole building with four horse stalls and one enclosed tack room inside. These stalls are open barred like a jail. The remainder of the building will be open. Is it required that all device boxes, including lighting fixtures, inside the general building area are corrosion resistant or only those in the confines of the stalls. It is likely that animals may be allowed to run loose in the general open area. I assume that enclosures inside the tack room do not require corrosion resistance.
