Golf Junkie
I'm looking for interpretations of 675.8(B) Main Disconnecting Means.
"The main disconnecting means for the machine shall provide overcurrent protection"
Does a UL98 non-fused switch wired to a fuse block in the control panel comply with this requirement? Or is the only acceptable solution a fusible switch assembly?
Thanks
Thanks
