Consider a 36? H x 36? W x 8? D ?Plug Box? with 277Vac female receptacles on one side and access doors on the other for access to terminal strips, etc. The 277Vac receptacles are heater output that cycle ON / OFF based on a Loop Control Temperature System. Into these receptacles are male plugs that power resistive element heaters.
Article 110.26 addresses ?Working Spaces?; but I?m not sure if this applies to this installation; ?Condition 2?.
If a receptacle does not have a plug installed it would be ?Disabled? and would not have 277Vac available. Receptacles that are in use, will have a plug installed and would not be on continuously but only cycle ON / OFF as needed.
Does this ?intermittent? voltage to the receptacles exclude the adherence to Article 110.26?
