This question deals with the 1999 version of the NEC. Our business is attempting to relocate into a a municipality that has adopted the 1999 NEC. We are having trouble getting a certificate of occupancy because the machines we use in the manufacture of our product are customized to produce a particularized product and the City is insisting that each of our machines be inspected and labelled by a testing agency such as UL. The City takes the position that article 110-3 of the 1999 NEC mandates this and mandates that all such machines be labelled by an approved testing agency such as UL. The cost to do this for each machine is prohibitive, and we do not believe that the 1999 NEC requires this to be done. Can anyone give me any guidance? Is the 1999 NEC generally interpreted to require a manufacturer with unique equipment to have such equipment listed and labelled? Any help would be greatly appreciated because I have not had much experience interpreting the NEC. Thank you very much for any insight that you can offer. Randy Wisener
