Red Wiggler
Can you provide me some interpertation for this article?
I need to provide the Clear Working Space for a 12,500 volt Switchboard. Do you calculate the clear working space from the gear to a grounded wall (Condition 2) as 6 feet? Or do you assume 12,500 volts measured from one phase to ground as around 7,200 volts to ground? In which case you could use the 5 foot clearance as depicted in Condition 2.
