mshields
- Boston, MA
A colleague of mine has encountered a client who believes that a handle protruding out the face of an ATS/with Bypass; i.e. the furthest part of that handle protruding from the front surface of the ATS enclosure, is the point from which you have to measure the 4 feet to the 480V equipment opposite it.
I'm confident that the clearance is from the front surface to the front of the opposite piece of equipment, regardless of any kind of breaker handles or in the example sited above, handles for putting the ATS into bypass.
Can anyone tell me where I would find the relevant verbiage in the NEC?
Thanks,
Mike
Thanks,
Mike
