I am having trouble getting past Article 210.23 "In no case shall the load exceed the branch circuit ampere rating", with respect to start up currents. I am using heat trace to heat a sample line. This heat trace requires 35A on a 30A (manufacturer recommended) circuit for a short time (60s, decreases over time to about 11A). Am I not in violation of this article (the CB will hold according to trip curve)? There must be an "out" as there are many devices that have switching power supplies with very high inrush currents (even though the time is very small). Please help.
