article 210.4 2008 nec
grumpy11
i understand this article when installing multi wire branch circuits.
question what if let say you install 6 circuits with 6 neutral in the same conduit entering a panel .does each circuit and neutral have to be identify as they enter a panel cant find where it says that.
It really is not different than 6 mc cables entering the panel. Now I believe each neutral should be identified with the appropriate ungrounded conductor.
That does not apply to the two-wire circuits mentioned in the OP.
Fooled by the title of the thread saying 210.4 :D
