1-38 Log #573 NEC-P01
Final Action: Reject
(100.Lighting Outlet)
__________________________________________________ ___________
Submitter:
Alan H. Nadon, City of Elkhart, IN
Recommendation:
Revise as follows:
Lighting Outlet. An outlet having intended for the direct connection of a
lampholder, a luminaire (lighting fixture), or a pendant cord terminating in a
lampholder, that is directly connected .
Substantiation:
Intent cannot be determined during an inspection. A junction
box with a blank cover, even one containing switched conductors, does not
provide the illumination needed for persons to move about safely thus
preventing accidents.
Panel Meeting Action: Reject
70-22
Report on Proposals A2007
? Copyright, NFPA NFPA 70
Panel Statement:
The proposed definition would require a luminaire
wherever a lighting outlet is installed. Code rules dictate where lighting is
required. CMP-1 refers the submitter to the panel action and statement on
Proposal 1-39.
Number Eligible to Vote: 12
Ballot Results:
Affirmative: 12
