jsinclair
- Pennsylvania
Still discussing this load study issue...
Now haggling over article 220 and its intentions. I take the stance that the intention of the article is to give an outline for sizing electrical installations for things that are not built yet. For example, if one was building a house, the loads would unknown for the most part. You would use the values as a guide to determine the minimum sizes. For existing installations, actual loads should used in the calculations. Where unknown, then the values outlines in article 220 should be used.
Can anyone shed some light on the intention of the article? :roll:
