dneff
- Provo, UT, USA
I have a piece of electrical test equipment in a small network rack. It has things like oscilloscopes, mulitmeters, waveform generators in it. I think the requirements below violate NEC Article 250. Could someone please verify for me?
1. The chassis shall have a redundant ground through the AC power facility (ground wire in the AC power cable) and a low impedance strap to the facility earth ground.
2. The grounding pin of the AC power plug shall be connected to the reference plane at one point.
3. Each primary power source shall have its neutral or return side electrically connected to the ground plane at one point only.
I don't think the neutral should be connected to the same ground plane that the grounding pin is connected.
I also think by connecting this same grounding plane to a facility earth ground via a low impedance strap is a violation because shouldn't the neutral only be connected to the ground at one point in main breaker panel?
I appreciate any help I can get with this one.
