FRANKY CHAVARIN
when makin a graunding connection to the cold water service which supplies a building ,what must be done if a water meter is installed within 10 feet from the building?
FRANKY CHAVARIN said:when makin a graunding connection to the cold water service which supplies a building ,what must be done if a water meter is installed within 10 feet from the building?
M. D. said:Same reason a network cable installer wants to know if tubing is conduit![]()
iwire said:Why does a painter want to know this?
