Smoothcarl
- Iowa
I'm working at a school right now running a lot of EMT. A question arose about how close i could run pipe to the edge of the metal stud. So naturally i turn to NEC hoping for a answer. Art. 300.4(A) is the closest I could get to an answer but I'm still not satisfied beings that the Article is talking specifically about wood members, not steel. I see that is says if distance cannot be maintained cable can be protected by EMT via exception No. 1 which is essentially the same thing as just running EMT in the wall but i still feel like a screw could puncture EMT fairly easy if for example an inexperienced new sheet rocker just didn't know any better. Obviously any idiot could just see the pipe in the wall but I'm talking worst case situation.
