Article 340 UF Cable
stevebea
Southeastern PA
Does all UF cable have a sunlight resistant rating? Situation is an apartment complex that is being rehabed and some of the condensers have UF from the disconnect to the unit. I know Article 340.12 (10) will not allow this as it is subject to physical damage, but this UF has been in the weather long enough I can not read a thing on it and I wasn't sure if all UF has a sunlight resistant rating or not. Thanks.
In reading the UL listing category for UF cable [YDUX] it appears 'some' UF cable is available with a 'sunlight resistant' rating, which is labeled on the cable. However, in reading through the category description of the various ratings available for UF cable, it does not seem that all UF cable is automatically rated 'sunlight resistant.'
