A coupling is a "fitting" and that is one of the reasons that the word fitting was removed from the code section in question. The change was made in the 1993 code. It was never the intent to require a support within 3' of each coupling, but the use of the word fitting in the older code versions did require a support within 3' of each coupling.
Don
