Sandlapper
- Coastal South Carolina
Gentlemen,
Is it permissable to transition directly to FMC or for that matter LFMC utilizing a properly supported condulet fitting? Have recently run into a project where it was suggested that a short nipple was required to make this transition. Is a T fitting consider properly supported when it is supported on two sides, or an LB on one side as per 314.23(E)?
Feel free to ask a few questions as I know this is probably not enough info to get to the truth of the matter. I'm usually as clear as mud anyway.
