howie conroy
- arroyo grande, ca
We have a differing opinion here. The situation is that a sign contractor used LFMC w/listed fittings as a pigtail from a j-box to the sign. It was adequately supported and not subject to damage. One side feels LFMC may be used anywhere conduit is needed (exposed to the elements) as long as the above conditions are met. The other side feels that LFMC is intended only for machinery etc. that needs flexibilty to movement and liquids/chemicals. The code does not seem to be black and white to support the first argument. The manufacturer's specs do seem to support the first side.
