garycheiro
- California
Can I use surface nonmetallic raceways (Hubbell-Wiring PS3BC5 -www.hubbell-wiring.com) in a plating shop? I'll install the raceways on a metal frame & on each end I'll connect a liquidtight nonmetallic fittings with manufacturers conduit adaptor (PS3CACF). According to article 352b (352-22 Use - The use of surface nonmetallic raceways shall be permitted in "dry locations") & (352-23 Other Articles - Surface nonmetallic raceways shall comply with the applicable provisions of article 300.) Thanks...
