Atlantec
- United States
A manufacturing facility currently uses a 60A, 3-pole 300V rated busway product fed with a 60A, 3 pole over current protection device at the panelboard. The facility uses a UL listed 15A, 3-pole, 300V rated non-fused plug-in "jack" which is has (3) brass spring loaded contacts and an integral junction box with (3) #12 conductor leads. The jacks are by the same manufacturer of the busway. They feed manufacturing equipment from these "jacks" using flexible cords with strain reliefs. There are hundreds of these types of equipment connections.
If listing the specific products used is OK with the Forum rules then that might help since this type of busway is not like "most" busway in that it is more of a powered track with multiple non-fused drops to non-fixed equipment.
According to 368.17, a 15A over current protection device appears to be required for these plug-in "jacks"....or is it?
