Hello,
I would like to better understand the fill requirements for non-metallic wireway (Panduit) according to NEC'08 section 378.22 one is required to calculate the maximum fill of Panduit to be 20%.
But, according to the NFPA 79 Electrical Standard for industrial Machinery 2007 Edition, it specifies:
13.5.2 Percentage fills of Raceways (Ducts)
"The combined cross-sectional area of all conductors and cables shall not exceed 50% of the interior cross-sectional area of the raceway (duct). The fill provisions shall be based on the actual dimensions of the conductors or cables used"
Also, according to definitions "wireways" and ?Conduits? are included under the term "raceways".
Which percent fill should I use?
Further, what does this mean for conduits on industrial machines? If I use NFPA 79, I can fill each conduit to 50% regardless of the number of CCC?s and NEC 08 chapter 9 table 1 does not apply.
