al hildenbrand
- Minnesota
- Electrical Contractor, Electrical Consultant, Electrical Engineer
2008 NEC Article 382 Nonmetallic Extensions.
I've just seen information on flat & wide straps of multi conductor cable that can be glued to the face of an already finished wall surface and then painted out, or skim coated and painted out.
As of the changes new to the 2008 NEC, it can be used with 15 and 20 amp branch circuits to extend from an existing outlet of another wiring method.
There is no physical protection for this NM cable on the surface of the wall.
Any one played with it yet?
What do you think of it?
