wmabantajr
Refer to the above article, my application is a modular service chase, bolted to a device level with the floor with gasketed plates that are level with the floor protecting it from the elements. This service chase is removable by unplugging it from the floor device and removing four 3/8-16 bolts. This system is used for versatility in the environment. I am using SJ cord with a 5-20P configuration molded plug into a 5-20R receptacle in the floor devise to make my connection. My question is does this fall in the above article as a permitted use?
