Is there a good distinction between cords and cables?
So far I've found
Cords are typically only in smaller sizes - but cables might be in those sizes too.
Cords are typically designed for indoor use only - but might be outdoor and a cable might be indoor only too
Cords are designed to be temporary installs while cables are designed for permanent installs - but what does that really mean?
400.7(B) does expect cords to have attachment plugs and be plugged into an outlet
So far it seems if it's a small size with anything but armor then the only difference is the attachment plug.
So far I've found
