Re: Article 427
Hmmm. But in place of a GFPE you can use a GFCI receptacle or ciruit breaker. If your heat cable is not too long it won't trip the GFCI. I have a lot of heat cable with GFCI's, but it is all pretty short runs under ten feet. Also keep in mind the new type heat cable has a braded metal sheath on the outside. also, I use the self regulating heat cable, wet location rated. I would suggest you look into the self regulating type as it only gets hot when the temp drops, the energy savings over having heat cable on all the time could be substantial.
the above is assuming it is 120V heat cable. If not 120 V and its 277 or 480, then you definitly want GFPE, due to the fire hazard if it faults.
