conmgt
- 2 Phase Philly
Class 1 Division 2 Fixed luminaires.
Would a vapor tight flourescent strip light qualify for this location. I'm thinking of the Simkar OV410 specifically.
The Article says that the fixture shall be protected from physical damage by guards or location. Would a wire guard suffice?
The Article also says that where hot sparks or hot metal might ignite vapors...a suitable enclosure or protective means shall be provided. I'm thinking the sealed plastic lens will suffice there.
The OV410 is described as a enclosed gasketed fixture equipped to tightly seal out vapor, moisture and dust. It's cover is a wraparound plastic lens attached with cam latches.
Any thoughts?
Any thoughts?
