Dale001289
- Georgia
I have an arcing device housed within an explosion-proof enclosure. I'm routing 3/C #14 from cable tray to the enclosure (no conduit). The cable is TC-ER rated, THHN/THWN, 90Deg C, Wet/Dry with 600V insulation and circuit is Class 2, per Article 725. The enclosure is in a Class I, Division 2 location. Does this connection require a cable seal?
