Article 511.3 definition clarification
mjmike
When reviewing 511.2 definition for a "Major Repair Garage", if the tasks performed under its definition do not require draining of the fuel tank, would this then be a "Minor Repair Garage"? For example, if an auto body shop performs "body and fender work" but does not drain the fuel tank, would this be a "Minor Repair Garage"? It is confusing as the definition for "Major Repair Garage", lists the tasks and then uses the word "and" as opposed to "or" for draining of the fuel tank.
I think the point of the code is that when fuel tanks are drained, the fumes escape and creates the hazard, not necessarily by just say pulling out dents on a fender.
Correction to title of the thread. Should say "Article 511.2 definition clarification". Maybe an admin can fix.
