We are working in a Natural Gas dispensening area. Some of the pipe is run in rigid with explosion proof fittings and then there is some that is run in EMT with screw tight connectors. We are installing power to go up to the roof from the panel and communication wire for a camera. The panel is over 30 feet away. The natual gas is purged out of a vent on the roof and the smell is very strong. The pipe run is less than 5 feet away. Our foreman wants everything done in EMT, from the panel up to the roof. I do not think this is correct. Any insight?
