buffalo1
- California
I am doing an ambulatory surgery center with two operating rooms and a 7 bed recovery room. It has a standby generator to provide emergency power. in order to not change the generator, (it is maxed out), the architect removed the vacuum pump which provides suction to each OR and bedside at the seven recovery beds from the EM panel and put it on regular power. I questioned this as being a violation of 517-25(b)(3). The architect also removed the lights over the recovery room beds, (1 each bed) from EM power and put 3 lights in the whole room on EM in their place stating that was enough light. I see this as a violation also.
Am I correct in these assumptions or is there another part of the code that I am missing?
