Im working on a new floating structure under the NEC 2011. We have a small condensate pump (208v - Single Phase) that is currently fed from a GFCI breaker located within the panel, within the floating structure. The GFCI breaker keeps tripping after the pump cycles on. Does anyone know if Article 555 requires all branch circuits within a panel to be GFCI protected, even if they are NOT 120v?
