Zane Bailey
This article requires that all parts specified in 680.26(B)(1) thru (B)(7) be bonded together using solid #8 awg conductors. This Article also states that this #8 solid awg conductor is not required to be extended or attached to remote panelboards, service equipment, or electrodes.
Does this mean that the parts specified in 680.26(B)(1) through (B)(7) are not required to have a low impedence return ground fault path back to the power source?
if so what is the purpose of bonding these parts together?
