electricdoc15
I have a question reguarding a permanently installed manufactured hot tub. I do a lot of work with in ground pools and am quite fimilliar with this section of the code. I recently installed the wiring for this tub using 6-3 non metallic sheathed cable as allowed by art 680.42 part C. After the disconnect switch I used a combination of PVC conduit and non metallic flexible conduit. I was told by the AHJ that the installation of non metallic sheathed cable does not comply because of the under water light. The light is part of the tub from the manufacturer and operates on a low voltage 12 volt transformer. I have also read the requirements of art# 680.22 & 680.33 Who is correct here? Thanks for your help!
