Article 680 and other outlets
eds
Kansas
Waiting on a customer so NEC is in the van. Article 680 section 11 has a rule pertaining to other outlets needing to be 10’ away. Will that require the disconnecting means for a minisplit be 10’ away along with the mini split. This will be a outdoor hot tub install
680.22(D)
