article 680
nj6768
An above ground permanently installed pool. Where does the 5 Ft. measurement for pool equipment I.E. pump motor start. Does it start at the top (water edge) or the bottom of a pool?
racraft
Re: article 680
Any point of the pool. Measure from the outlet to the closest point of the pool (top, bottom, middle of the side, metal ladder, whatever).
[ April 05, 2003, 04:54 PM: Message edited by: racraft ]
russ
Burbank IL
Re: article 680
680 wording is "5 ft. from the inside wall".
To me it only makes sense that this is a strait horizontal line from the pool. If you were to measure from the waters edge and you had a 5ft. wall on the pool the receptacle could be on the pool wall edge. That just doesn't seem right to me.
Russ
