Can I run pvc conduit with electrical wires (scedule 40, 24" below grade) in the same trench with the gas line? or it needs separation.
Thanks
NEC has no restriction on it, maybe the gas installer does?
680 is for swimming pools, fountains, spas - what does this have to do with your question about the gas piping?
Maybe he wants to run the electrical conduit in the same trench as the gas line for the pool heater.
What difference would it make if it was in the same trench or another trench?
Once it is burried it is in the same earth. The only thing you should be concerned about is any separation that may be required by the gas code.
Where I am in oregon the inspectors require a 1 foot seperation, be it horizontally or vertically.
