If a fire pump feeder in conduit is run straight through a hand hole in conduit (no breaks) that contains other wiring in violation of NEC? I not sure if it meets the intent of this article. This was a field decision made by the designer after the violation was noted. Originally the conduit enter the common hand hole and wiring was not independent as required. Thanks
Jim
Jim
