Emergency lighting systems shall be designed so that failure of any individual lighting element such a burning out of a lamp shall not leave in darkness any space that requires emergency illumination.
My question is, if I use a (1) LED wall pack over an egress door and the lamps are wired in parallel on the boards does the fixture need (2) drivers and separate boards?
