ggunn
- Austin, TX, USA
- Consulting Electrical Engineer - Photovoltaic Systems
Most of the generation of electron-hole pairs occurs in the bulk semiconductor, not at or near the junction, so they immediately recombine. Quick question - have you studied this formally or are you just google searching wikipedia articles? I majored in the semiconductor device block of my EE department; everything I am saying is from memory, and as I said, it was a long time ago. I just remembered "avalanching", though, so you might look that up.Most? If the wikipedia article is correct that the single junction theoretical efficiency limit is 33%, and if commercially available panels are 20% efficient (is that right, and are those single junction panels?), and if the photon creating a hole-charge pair is the way that PV turns light into electrical energy, then it would have to be less than half. Certainly premature recombination would make sense as the primary mechanism for the efficiency discrepancy between the theoretical limit and the currently available panels.
Cheers, Wayne
