sirdle
- California
I don't work much with communications equipment and I'm not sure which code articles apply or even where to start looking.
I often see PLC cabinets installed in Tank Farms. In addition to 120V ac and 24V dc equipment, these cabinets might include:
A) PLC-based RS-485 communications module connected to a remote Modbus instrument.
B) PLC-based TCP/IP module connected to a din rail-mounted Ethernet switch.
C) Power-over-Ethernet switch connected to a remote spread-spectrum radio.
D) Protocol converter to switch between Ethernet and RS485.
1) Are any of these devices considered "Communications" equipment?
2) Would the cables connecting them be covered under Article 800, 810 or 830?
3) Or would these be considered to be extensions of the Class 1, 2, and 3 circuits covered under Article 725?
Thanks
Thanks
