Article 90.7
sokkerdude
Arkansas
I have a nema 1- 300 hp VFD that was located to far from the motor. I took an old 4ft by 3ft by 8ft enclosure and mounted the nema 1 VFD in it.
Does this fall under 90.7 as electrician added equipment to a listed motor controlled enclosure
which requires a field safety inspection by a recognized testing agency to re-certify, list and label the equipment added per 110.3 A . Does the old enclosure need to be re-certified? Any help would greatly be appreciated.
