mark henderson
- Leander Texas
I looked at a botched attempt to add a sub panel. Firs it is an old rag top service. They removed the guts to the exterior panel leaving no means of disconnect, they then spliced a three wire feeder to new 200 amp interior panel in witch the new branch circuits are all grounded. They have the neutral and ground bond there. The inspector came out to look at a new ac unit installed and discovered this. At this point I was called to give a quote to bring up to code. I included in my proposal to add the needed 4 wire feeder. She had some other electricians quote with out it. To get to the point I am trying to locate the articles to back up my estimate.
I have looked at 220, 408, 250.134, 215.,
Am I just missing it our what?
Mark
Mark
