Asco Lighting Controls.
Tones32
NY
Journeymen IBEW Local 3.
Hello All:
Here’s a scenario I’ve encountered on my latest job site.
Open Area lighting Fed from 4 different electrical closets which are on separate risers. Can you install 4 lighting circuits to 1 Asco 917, 1 circuit from each electrical closet to the same Asco. Is there anything in the National Electrical Code that states this cannot be done? This will also have 1 override Switch in the field and 1 DGM-100 Torx time clock.
Hello All:
Done all the time. It’s a good idea to label the panel circuit numbers for future troubleshooting.
