puckman
- ridgewood, n.j.
I like to ask some people who have work with asd or vfd for some help with these drives.
My company seems to make changes to equipment without any though to engineering their equipment. They have replaced across the line control with asd or vfd without changing the motors or wiring. These motors are mostly for pumps above ground and some for submersables.
Should these types of changes be made as a complete unit , correct type of asd , inverter duty motors and vfd type wire ?
There has been asd's replaced for atleast 4 different motors all between 5 - 10 hp for a start . The asd last 2-3 years and then need replacing do to damage. They operate at about 40 hz.
Should submersables 40- 75 hp use wire rated higher then 600v if on a asd ? ASD techs say units have filters built in drives.
Thanks for any information with the installation or troubleshooting process you can advise will be use and helpful.
