1. For a product meeting ATEX 3, what are the basic requirements and what standards (number) apply?
2. Does ATEX 3 only require manufacture's declaration of conformity and if so, what part does TUV, for example, play?
3. Is Type n the protection method that best applies?
4. What is the difference between non incendive components (code letter C), non sparking apparatus (code letter A) and energy limited apparatus for Type n protection?
5. I have a product that is designed using only IC's and direct drive LCD's with approximately 2.2uF capacitance, no inductance and has no relays or power supply. Unit power (Vcc and circuit common) and serial communication are supplied to the device thru 13V zener barriers. Given this data, what Type n protection best applies.
6. Where does the additional code letter (C, A or L, whichever applies) go in the ATEX Marking? ex: EEx n IIC T4
7. Must the product also meet CE requirements and if so, what standards apply to the product?
