So I'm going to look at job a little more in depth tonight a little back round
This is commercial building with about 9-10 ats switches feeding multiple loads off of one generator
They had a generator service company come out to test and diagnose the functionality of the ats switches they found that 2 out of the 10 did not have emergency power while in test mode and the generator running but there are wires ran and terminated to the emergency feed in the switch
After a brief visual inspection it looked like to me the generator may have feed a Mdp and then from the Mdp it was supplying multiple ats switches. My question is .. is that a normal set up for the guys here that do large job with generators. Do you typically feed an Mdp then Branch out or does it come off.the generator into basically a large splice box or.trough or whatever to feed the multiple ats switches
My thoughts were if the generator was feeding this Mdp one of the breakers feeding the individual ats with no emergency power could be bad
Sent from my SM-G965U using Tapatalk
