attached added building
jman1391
New member
do u need to put seal tight between an excisting building and an attached addition wen going through concreate walls? and were do i find it on the code book?
Is it a "wet location"? What type of construction is it: Type I,II,III,IV, or V ? What is the occupancy group? R,S,U,B,etc.
I am not sure you will find it in the code however, you may need to protect nm cable when penetrating a concrete wall if the inspector considers it subject to physical damage. I usually put a sleeve of pvc thru the wall.
Art. 334.15(B) would be the article
