Re: Attached & Buried
Dave I have run into the same situation here also in Florida,Pool prewire not installed on rough in.Either due to not being informed at that time or simply rough in crew missed it.
Some truss deigns do not allow for a retro after drywall and have been asked by GC can we not tear up landscaping and run it along building in PVC.,but just below grade so as not to be seen.
I felt that would be the call of AHJ in the area.So I did as sugested here called and met him onsite,told him the situation.Simple reply if it is straped to the building it has to be above grade and visible,not below mulch grass etc. That way it can`t be damaged by a mower etc.
Gc opted to run it above grade and paint it brown to blend in with mulch
,another option is to pop a few soffit panels and run the nm in that area then exit down the wall in pvc.i have found the biggest problem is not the pool feed but the pool light switch leg,always seems that it is wanted to be in an area that you can`t get there from here without major drywall damage
