ivsenroute
- Florida
The funny thing (not so funny) is that I catch stuff like this all the time on new construction during final. The initial rough was good, they made some changes afterwards and this is the result.
Due to depth perception of the photo and the steep roof, there is around 48" + from the wire to the bottom of the rafters
Okay that changes things but all these threads you have started not any of them had me freaking out worrying. I have seen 100 times worse all over the place.
You're right, I constantly see things 100 times worse. Then again its usually HO existing work I'm looking at. These pictures may be showing work done by licensed electricians who are thinking that they're going to pass an electrical inspection.
Dennis, you wouldn't sink them, if the roof had a higher pitch? Or run on a stud ?
The 48" is good for a wall to enclose something just depends on the roof pitch?
Jude, I was just saying it was legal.
I square my work so "NO" I wouldn't run across the studs unless it was in the very corner and then I usually staple to the rafter to stay out of the insulators way, esp. when 2x4 trusses are used.
This looks compliant to me.
I'm not following - There's 48" between what and what?Okay that changes things...
