heath harry
I received the following statement from a client and question if it is actually possible for somebody to have jurisdiction over their own plant? If the following statement is true, would they not have to at least have certified inspector?
"It is now prudent to state exactly what the NEC is and what it is not. The NEC is article 70 of the NFPA (National Fire Protection Agency). The entire mission of the NFPA is to reduce the worldwide burden of fire and other hazards on the quality of life by providing and advocating scientifically based consensus codes and standards, research, training and education. The NFPA is an independent, nonprofit organization. The NEC (NFPA 70) focuses on the proper installation of electrical systems and equipment to protect people and property from the potential dangers of electricity. Neither the NFPA nor the NEC is a governmental body.
It is left to the State whether to form a licensing body, which would then review the latest NEC and adopt or reject those portions it saw fit for the state. Colorado is an example of a State with a statewide licensing body. Where a State does not have such a statewide licensing division such as Texas, it is then left to the local governing body, which has the right whether to adopt or reject portions of the NEC. For example, the City of Houston?s Electrical Board meets every three years when a revised NEC is published and decides what portions of the NEC to change, adopt or exclude and then revises its masters electrical licensing exam. The city controls installation of its electrical system by issuing permits that may only be obtained by its licensed master electricians.
The authority having jurisdiction over A XXX COMPANY would first fall to that municipality in which the plant resides. If that municipality does not have a code enforcement division, it would then fall under any county enforcement division. If there is no county enforcement division, then XXX COMPANY is considered the governing authority except where the providing utility company has authority for what it considers safe interconnection of its system to the customers system.
Since the primary reason for not installing a field mounted disconnect for the crane rails is safety, XXX COMPANY has the authority, responsibility and obligation to make this decision."
