Rick Christopherson
I want to get someone to confirm my thoughts that if the input of an auto transformer is GFCI protected, then it's outputs should also be GFCI protected.
I am looking at a point-of-use, cord-and-plug connected, 120 to 240 volt 1000W transformer. I popped the cover and confirmed it is a common-neutral auto transformer. My initial thinking is that if there is a ground fault on the output, that it should trip the supply-side GFCI if it were plugged into one. (Yes, one line at 240 is in fact tied to a common neutral, like a European system.)
Am I over looking something, or does this sound correct?
